I should mention that I know there are many threads like this, but I am not a geek and do not know the meanings of the terminology, and I also have many questions to ask so please bear with me.
I have a galaxy note which was running 4.0.3 which I got OTA. Two days ago I successfully rooted the device through "CWM recovery" and installed Franco Kernel. This was done successfully, and seemed to make absolutely no difference to my phone, whatsoever.
Anyway, since my goal was to install CM9 and then CM10, I tried to install a GB ROM (which I understand is necessary as going to CM9 straight from ICS can cause a brick)... I did this by installing the "Abyss" Note Kernel. I tried one version which was "custom" and the other "original"... neither of which proceeded past the booting sequence, despite being successfully installed.
No problem. I would just go back into recovery mode and re-install the Franco Kernel, and my phone would boot and operate as normal.
However, last night I had installed one of the "Abyss" kernels (the ones that don't proceed past boot), and I had low battery so I just pulled the battery, and reconnected it and put it on charge but did not turn the phone on (left it with the battery charging animation overnight). This morning I went to turn on the phone and it wouldn't go past boot. "Ah, of course, the Abyss Kernel doesn't work", so I went into recovery and reinstalled Franco kernel so that I could use my phone as normal, only to find my heart sink a little as I realized it wasn't proceeding past boot. It just stays on the screen with the flashing "SAMSUNG" logo.
Please help!!!
Please help!!!
