Root Please help im a noob
Jbrown93
Hi, I am trying to root my evo but I am new and im on ubuntu. As soon as I open unrevoked on my ubuntu computer it wont recognize my evo and continue to root the phone. Can some one help I tried it on windows and that didn't work either. Any help is much appreciated
Ouch! I guess going over to XDA forums would be your best bet. Developers are always up for the challenge, but since you're the only one I know who runs Ubuntu, it might take some time but don't underestimate the people from XDA. :)
Do you have hboot 2.02 or 2.10? If so, you may not be able to root using unrevoked right now. If you just bought your phone it may have either of those hboots. You can check by powering off your phone, then holding the power key and volume down key until it boots into recovery(?). Look at the second line, it will say "HBOOT- X.XX.XXXX", where the 'X's represent numbers. If it is 2.02.XXXX or 2.10.XXXX you won't be able to use unrevoked to root right now. But, there is at least one other method to root a phone with these two hboots at xda developers forums. Please search there.
If your hboot is lower than 2.02 unrevoked3 should work. That's what i used to root my EVO. Could you describe what's happening either on your pc or phone when you try to use revoked?
