Hey all,
I'm having issues rooting my TB using the revolutionary method
I did do the OTA update when it came out
However, I did downgrade back to previous version as I read could be the issue in other threads
Here's where I'm at now....
Mount phone as disk drive with USB debugging on
Run revolutionary. It asks yes or no for clockworkmod. I say yes
Everything goes smooth. I reboot into bootloader
This is where the issue comes in
Normally I press recovery and it takes me to clockworkmod where I can flash superuser
Instead I press recovery and it goes to a screen with the red triangle
I rooted my previous TB without the update just fine
This TB I did the update and now I can't root
Any help would be greatly appreciated
Thanks in advance!
Thanks in advance!
