Ok.. I am an admited NOOB and have officially reached the frustration mark in trying to root my bionic. I've been to a ton of threads from different places and get confusing and outdated info so I thought I'd give it a shot here. Here is what i'm experiencing..
I have tried to root my Bionic using SuperOneClick, Motofail, etc. SuperOneClick gets hung up at step 5 and then stops. Motofail is the latest try and i've attached the dialogue box below that hopefully helps. I'm using Windows 7 on an ASUS PC. My Bionic specs are: SYS VER-5.9.905, Android VER- 2.3.4.
I made sure the USB developers option was on, I did not mount my SD card, I tried in both Charge only and USB Mass Storage modes, updated all my drivers, and ran things in administrator mode. Here is what i'm getting from Motofail:
___________________________________
[*] Motofail: Universal Motorola Android Root Exploit (Windows version)
[*] by Dan Rosenberg (@djrbliss)
[*] Tested on Droid 3, Droid Bionic, Droid RAZR, and Droid 4
[*] Before continuing, ensure USB debugging is enabled, that you
[*] have the latest Motorola drivers installed, and that your phone
[*] is connected via USB.
[*] Press enter to root your phone...
Press any key to continue . . .
[*] Waiting for device...
* daemon not running. starting it now *
* daemon started successfully *
[*] Device found.
[*] Deploying payload...
cannot stat 'motofail': No such file or directory
Unable to chmod /data/local/motofail: No such file or directory
[*] Owning phone...
/data/local/motofail: not found
[*] Rebooting device...
[*] Waiting for phone to reboot.
[*] Attemping persistence...
remount failed: Operation not permitted
failed to copy 'su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
link failed Read-only file system
failed to copy 'busybox' to '/system/xbin/busybox': Read-only file system
Unable to chmod /system/xbin/busybox: No such file or directory
/system/xbin/busybox: not found
failed to copy 'Superuser.apk' to '/system/app/Superuser.apk': Read-only file sy
stem
[*] Cleaning up...
rm failed for /data/local/motofail, No such file or directory
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
________________________________________
In the dialogue box in SuperOneClick, I kinda got more or less the same type of stuff. I've used two root checker apps and both come back with my device is not rooted despite Motofail indicating otherwise. I hope someone can help me with this. Any assistance will be beyond appreciated...
[*] Device found.
[*] Owning phone...
stem
[*] Cleaning up...
[*] Rebooting...
