please help me about phone kernel
prance666
when i used creiskelo or any rom and crieskelo kernel and Siyah-v2.0 and Jeffrey-SpeedFrey2.1 my font dont boot and freezing but when i used any rom and speedmod-kernel-s2-k2-2 and CF-Root-SGS2_XX_OXA_KI3-42-v4.2 kenel no problem and my phone is runing
please help me
You're doing the only thing possible, which is find out by trial and error which ROM/kernel pairings work.
Always wipe cache and dalvik-cache (via recovery) before changing kernel. Also zero-out any clock frequency or voltage changes back to stock, as different kernels have different parameters.
if you're happy with the SpeedMod/Criesklo combination then stick with it. As I said previously there's no easy fix for an issue like this, other than finding a setup that works for you.
There's no help to give you, sorry. If a particular kernel won't work with your ROM then you'll have to contact the developer to work out why.
