Help Please help me asap?? Youtube not working?/
elcocho852
My youtube app is not working at all, please help me out?? When i go to the website on my phone it doesnt even load i want to know whats going on?? I could go on pandora, and all other streaming apps but youtube is not working..
Phone is rooted or no?
If you can, uninstall and reinstall it. Try rebooting your phone. Maybe it is just acting up and will fix otself in a few days. I actually had the same problem earlier this week and aftera few days it was fine. The issue was quite annoying but no overall damage to the software
Yes I'm rooted and I have the Ginger esteem extreme rom with the Gingerfusion theme.. I already uninstalled the app and reinstalled it but it doesn't work?? What should I do so it could work???
@gbiggie How do i Fix permissions in recovery?
@epayne123
Yes it has always worked since i installed the rom and what do you mean by GS OG or GSE?? This is the name of the rom GingerSteem_Extreme_signed if this is what you are talking about..
I do have TB, but i dont use it to freeze apps, i just use it to back up and restore apps and yes the website doesnt even load and the app just stays loading but never loads anything???
Take a look at your app...settings manage applications. Look the same?
http://m.box.com/view/f_1580955577
I went through the same thing for about a month or so. Finally metro replaced the device and now it works. I tried everything. Metro "Advanced Network" support tried everything. Rooted/Not Rooted/Stock/ Gingersteam made no difference.
Here is a screen shot of my app.. The only difference i see is the app's size???? What do you think??
