Root Please help me big big trouble!!!!
navid
hey everyone when i was trying to change some files on my root files the phone hung and when i removed the battery and tried to start it again it only shows the SE logo i can't restore it too what can i do?tnx
i also had similar problem mine was worst i deleted all the inbuilt apps
solution is remove ur battery for 30 minutes and then try again booting :):):):):):):):):):) it worked for me
Don't Mess with your phone if you don't have xrecovery
