Root Please Help Me Downgrade
leoskullz
I would really appreciate it if somebody could help me downgrade from the leaked ota/unroot. I'm on Software number: 1.36.605.0
I'm also on a mac; I'm not sure if that makes a difference or not but I couldn't really follow the instructional videos because they used some other method on a PC.
I'm able to get the zip on the sd card. That's not the issue. My phone never actually installs the zip, which I guess is where the problem is. Do you think its the SD card formatting or something? (off the subject of mac hate lol)
Your SD card needs to be formatted to fat32 and if you are asking about the PB31IMG.zip file it is case sensitive and needs to be in the root of the SD card and is flashed in the hoot screen
