riverboat2001
Sorry for double posting/starting a new thread, but i'm really starting to miss my wifi now.
Quote (in red) below from weirdNumber
Mine is a Desire that i have previously debranded.
I have formatted an SD card, copied over the downloaded zip file, re-named it, but it fails with incorrect CID.
Do i need to create a Goldcard again?
I basically did the same thing that I did when I debranded my phone.
You need a goldcard (Lekky has a guide on his website) then I installed the
RUU_Bravo_HTC_WWE_1.21.405.2_Radio_32.36.00.28U_4. 06.00.02_2_release_126984_signed.exe from RUU_Bravo_HTC_WWE_1.21.405.2_Radio_32.36.00.28U_4. 06.00.02_2_release_126984_signed.ex - xda-developers
I said it was from Modaco earlier which was my mistake.
I suspect if your phone is already a generic one then you can just download the zip from that thread and follow;
Quote:
Originally Posted by i6bazar
It worked for me today.
Procedure I used :
1- Copied the zip file on the uSD Card
2- Renamed the zip file to PB99IMG.zip
3- Turned off my desire
4- Turned on by using VolumeDN+Power keys
5- Selected fastboot
6- Desire loads the zip file then asked me if I wanted to flash the new ROM by pressing the VolumeUP Key
7- Restarted 2 times and the new rom was there
The procedure didn't worked if I tryed to rename the zip file into update.zip and went in the recovery menu, I got an error like "invalid keys detected"
Procedure I used :
