jk_sangre23
Hey guys, newbie here. Just got my phone 3 days ago and there are a few things that I can't figure out. This is my first android so please bear with me if my questions are a bit dumb.
1. In messaging, I type my message and send it then I exit to/go back to the "Inbox" (if that's still what its called). "DRAFT" appears on the area where the time the message was sent should be but I still get a reply. Is there a "DRAFT" box and how do I access it?
2. Same issue as others I've read here, my phone gets hot. Is this something i should worry about coz there was a review on Youtube by SAMJPULLEN and he said: it's ok if it gets hot, you should start to worry if it doesn't". So which is which? should I or shouldn't I worry about it?
I hope you guys can help me out.
3. Is "ROOTING" a must? What are the Pros and Cons of Rooting?
