please help me root
no-idea
Member
for the love of god, someone please help me root my eris. im ready to brake my phone because of all these little glich/bugs.
im on a mac, but i also have my wifes laptop which is win. xp.
i cant even get sdk on my mac...
Check out the All things root subforum, and ask in there. Having done it on a Mac myself, it is much, much easier on a Mac. (As long as it is an intel rather than PowerPC Mac.) It is easier on a Mac because there is a weird step for Windows machines to add a USB driver that seems to stumble up many people. With a Mac, it just works.
Note that when you read the instructions, it will tell you to run a bunch of commands from a command prompt. The Mac translation of that is to run the application called Terminal, and type the commands in that window. And any instructions that tell you to type a command that looks like this:
adb ...
you will type a period and a slash before the "adb" instead, like this:
./adb ...
The basic instructions are in this thread: http://androidforums.com/all-things-root-eris/53963-guide-stock-1-5-latest-root-2-1-a.html
However, some really good information is in this thread, starting with this post, but the user erisuser1, who was walking JrzDRoid through the process: http://androidforums.com/all-things...placement-eris-root-questions.html#post827552
The SDK is here: Android SDK | Android Developers
Download it and install, as you would any other app.
And let me recommend that, if you do this, and are able to do this, when you get to step 3 and need to pick a ROM to use, that you use Ivan's Official, which looks and feels just like the official 2.1 Eris update, without the bugs or problems?
