Help Please help me!!
OK so i have a biiiiggg problem I went to root my new device and only afterwards realized that i cant find the official android 2.1 sbf files for mts. My phone boots up into a droid os and is asking me to activate and it cant every time i usually only have like one bar. Can anyone help me reset it to stock please help me
OK i think i may have found a fix if i take the sd card out and put it into my computer put on it the .zip file that is the right firmware and i hard reset it and install it from there would that work?
Where is the MTS network located? What country are you in?
P.S. The zip file you are talking about is only for rooting.
P.P.S Why do you need to find MTS ROM for rooting?
P.P.P.S Use z4root to root the phone.
ok well can you tell me how to get it back to factory settings. I need a copy of the milestone android 2.1 os because right now my milestone has a DRIOD os on it and MTS is a service provided in manitoba Canada its a subset of Bell mobility
yes ive seen that site before but for canada it only provides telus either way when i try it, it returns
critical error 1337 510B
i dont know if it will help but i had accidentally put a droid cyanogen rom on thats what i mean by my phone has a droid os please can someone help
