Help Please help me?
:confused:HEY GUYS,:confused:
I need some serious help here. I have been running GO LAUNCHER on my DROID CHARGE for a couple of weeks now. I had also down loaded SWITCH to go between GO LAUNCHER and original TOUCH WIZ.
Today when I tried to switch back to TOUCH WIZ my phone rebooted and than just started giving me this meassage:
THE APPLICATION TWLAUNCHER
(process com.sec.android.app.twlauncher) has stopped unexpectly.
Please try again.
This is all it does now, I can't load either launcher to get my phone back up and running.
What happened here? Did GO LAUNCHER cause this? How can I fix this?
Please help?
PS: Also my battery was getting very warm and was at 95% at 4:00 pm and almost dead by 6:00 pm.
Negative. Phone opens to screen lock (sliding glass) and when I try to slide open it freezes and eventually gives me error message.
Sometimes I do get to homes screen and can get into contacts, messaging or phone but nothing when i press menu button.
Your quickest option would be to go to a VZW store and get it exchanged.
Alternatively, and I have no idea if this will work or not, you could try turning off the phone and pressing and HOLDING the volume up key, the home key and the power key until the samsung logo pops up. Once it does, let go of the power key.
Try doing a factory reset from the menu that pops up (if you can get it to pop up).
Great. So basically GO LAUNCHER or HOME SWITCH caused this?
This really sucks.
So what is this issue anyway/ what does the error message mean?
Sorry for bothering you so much but I just need to know. Is it something i did?
Thanks for your time.
TBH, I have no idea what caused it or why. :(
Since you aren't rooted, I doubt it was something that you did :)
My best guess, just a bad phone. I've had 2 Charges, a Samsung Epic, HTC Evo and HTC Hero and haven't had this issue on any of them.
Well I guess I'll give it a try at your suggestions with the buttons and trying a hard reset first. Keep you up to date.
Thanks again for your help.
STEVE
