Root Please help need to sbf
FoxyDrew
Ok so I rooted my Bionic on Ics and used Droid Bionic recovery bootstrap Recovery and then flashed a CM9 rom. I didn't use safe strap and now I'm stuck on the lightning CM9 boot animation. Anyways my computer wont let me install RSDLite so i cant sbf. Is there another way to fix this?? All help is greatly appreciated because its not my phone! BTW i can get into stock recovery and all that using vol up an down + power
Did you wipe data/factory reset in recovery before you restarted the phone? If not, and if you cannot get into CWR, you could try that in stock recovery - there is an option for wipe data/factory reset.
Also, which CM9 ROM did you install? Do you have a link? It's quite possible that it requires Safestrap in order to run (if it requires a kexec kernel extension.) If you provide a link to the CM9 ROM that you installed...
Otherwise, you may need to find a computer that runs RSDLite.
Just curious
1) is it your phone?
2) why can't you install RSDLite?
Just curious
ok well no its my friends phone i told him i root it for him and flash a rom but anyways it did need safestrap to install so i screwed up and i used a different computer got rsdlite installed tried to flash the official ics xml file and it failed on 1/22 so now i cant flash it any ideas??
Edit: Turns out my battery was dead so I charged it and it worked phones fixed lol?
