OK. This will work as same thing has happend to me. Dont panic !There is a way for you to get your 4g back.
This method is to fix and reset 4g in general , so it should work;
First of all, download an app called "any cut" free from market. Then after it downloads and installs, go home screen and create a shortcut >then select > activities > and then select the "any cut" app. After that it'll send you to the app and from there you have to press on "activities" option and Scroll down until you see "LTE configuration" (its mostly the first one that starts with LTE). Then as you select that it will have created a shortcut action on the home screen. You then go to home screen and look for the shortcut you have created, it'll be called *lte configuration*. Open it and then press on setting initialization. Now, it will reset your lte settings and the phone will reboot. After that you should be able to be running 4g nice and clean...
Hope it helps ...
