I was running the JI6 2.2 with cognition beta5.5 and was attempting to update however I needed to swap kernels since the current kernel didn't verify signatures. I was using vmware on a mac and i started it but then continued to use the mac side however the computer disconnected the phone from the windows side and now it is stuck showing an image of a phone next to a computer with a triangle with a ! in it between the two. Pressing all hardware buttons does nothing but black the screen and go back to the same screen. I've taken out the battery, sim, unplugged the cord, everything. Can't get back into download mode to redo the kernal swap. It's definitely connected to a valid, and working, usb port and i am now on windows itself instead of vmware. What do I do???? Thank you soo much if you help out.
