Root PLEASE HELP!! STOCK KEYBOARD!
Karris
HELP! :(
ACCIDENTLY UNINSTALLED MY STOCK KEYBOARD (Note 3 Sm-n900t running 5.0 touchwiz)
I have tried numerous times to get it back or download other stock keyboards with apk, but none seem to work. I really want my original stock keyboard back!
If anyone could help me it would be greatly appreciated.
I AM rooted, but am not running any recoveries (CWM, TWRP, etc.) and my phone is NOT flashed.
I am currently using a keyboard from Play Store for now.
If anyone could post a video on how to get the stock keyboard back it would be appreciated,
Or tell me how to do it and send me an apk file would work also!!
Thank you!
Its funny how you can uninstall anything when you root your phone. However... due to these kinds of problems you should always have a backup Of your custom ROM. You'll have to flash original firmware from sammobile.com/firmware using the Odin software on a PC. I would suggest unroot your phone and reset factor data before flashing your custom ROM for a fully refreshed Flashing.
I did this already, and it did not work.
all it says is "Unfortunately Samsung Keyboard has Stopped Working" non stop.
Post a Screenshot of your Firmware details (Like take a screenshot of your about device) and Post a screenshot of The problem.
That is what occurs. I downloaded the normal firmware and everything but it did not fix the keyboard. I am currently using one from the Play Store.
What was you stock ROM.?? Was it 4.4.2 or 4.4.4 ??? Cause you need to flash it i guess and then aging update your phone. The problem is quite weird. Ne wayz. Do a Proper research and try to flash you stock ROM
