Help Please help with launcher
assdan
So I bought my first droid about a week ago, I bought a droidx and didint do much with it at all and decided I really liked the bigdxserenity theme. So i rooted my phone, put the glass928 theme on there for the deodex, now got the bigdxserenity on there.
Now I am trying to customize home screen to add different stuff like just a calendar but im totally lost now, I dont understand if the theme came with its own launcher or not but when i downloaded the free version of launcher pro it isint themed over at all and im not finding any of widgits themed like in the pictures like a calander, digital clock or anything.
I dont see anyone else with this problem so im guessing its really simple and im being stupid, plz help
As soon as you download Launcher Pro it will take over your home screen... Delete / remove Launcher Pro and you will be back to the 928 screen...
Well I like launcher pro, but its colors are not themed with the red and black colors like the ones in other pictures i have seen for the bigdxserenity, are they using a different launcher that is was installed somewhere when i applied the theme?
then use adw with the black and red theme its in the market and free
To my knowledge, you cannot use 3rd Party themes with LP/LPP unless you are rooted and running a rom. The only thing you can truly do is manip icons, launcher bars, and obviously use LPP based widgets.
I too would suggest looking into ADW launcher if a theme is what you ultimately want. Lots of options there, most are free and can be downloaded from the market.
Yes you can and I have a current 8.1.1 red themed LP if the OP wants it.
You still have to pay for Plus and enter the code that gets sent, but you can run it as the free version no problem.
You do not need to be rooted even though the OP is.
I think I explained it wrong, what I wanted was a explored that actually used the red and black theme like he had it. I found it right on the sd card under !bigdx. So im just dumb and didint know where to look.
In that folder it contained the explorer that was themed and all of the widgits and apps also themed so now it looks great, thx neways though
