bump! I have the same problem. I found this https://www.youtube.com/watch?v=VEIvk-nYLoM#t=148 . Not a source but may be similar. I believe the problem definetly involves the charging port. My screen started going on and off and the colors would change when I moved the charger plug around in the port, or even outside the port, just barely touching the metal part of the port. Let me know if you find the problem.
