If you want to just put a new custom rom on your phone, its simple enough. Just go to the ROM section here and pick a ROM that you like the looks of. Then install it using clockwork or SPRecovery, whichever recovery system you have. If, on the other hand you're looking to UNROOT and go back to stock just follow the instructions at the following links. They are very helpful and straightforward. I used them to UNROOT when I had an issue with my phone and needed to get a replacement from Verizon.
**At this link you can download the files you need and it includes the same video as in the first link but with easy to follow step by step written instructions. http://www.youtube.com/watch?v=AEj_grcVK24
