Root Please help
missjamie
I am trying to restore my phone from a backup since it currently won't boot up at all. i am getting an error that says can't mount data. I also tried to reinstall the rom and getting the same error. Is my phone bricked? When I try to re-install OMG5 Rom there are 2 errors. One is can't mount Data and the other is failure at line 7. Installation then aborts
Try a different sd card or reformat your current one, make sure to format it to fat32. Or can try reflashing clockwork.
Ps are you trying the omgb rom? I'd flash 6 or 7 not 5.
