My brother has a droid x and he is sick and tired of the phone not working right, im trying to convince him to root and flash a diffrent firmware and such
can some one tell me step by step on how to do this.. I flashed and rooted my fascinate and it works great. please can someone help
thanks
Basically you need to get z4root
[APP] z4root - xda-developers onto your X into the root directory on your sdcard. Then use explorer, astro file manager, an app installer or similar and run z4root. When it comes up select permanent root.
Here a list of what to do:
Root with Z4Root
Download
Droid X bootstrapper. Go to app and hit the top button "bootstrap recovery" grant it superuser permission and then it will say success (then you know you are rooted).
From here you have 2 options:
1. Hit the bottom button to reboot into recovery.
It will reboot into a screen with green words and such. To navigate use the volume rockers and select by fully depressing the camera button.
Scroll down to backup and restore, select it, and then select backup. It will take about 5 minutes to complete. You can find your backup located at sdcard/clockworkmod/backup/'date of backup' which you can rename as long as there aren't any spaces or ()'s.
2. A different way to backup is download Rom manager. Open it and click the top most button "flash clockworkmod" after that scroll down to backup current rom, give it a name and it will reboot and do its thing. The backup will be in the same place as before.
3. Download Titanium Backup (I suggest purchasing the Pro version) and make a backup of all of your user data and apps. With the Pro version you can do batch backup and restore which allows you to restore single apps.
4. Once rooted. Find and download a rom and install it according to the directions of the dev. Once you get your new rom installed and all of your apps installed and everything set like you like it, then make another backup using BootStrap Recovery. Some rom's you could test drive are Apex 1.4.1 (probably the best for starting out with), Liberty 2.x, DarkSlide 4.2 (this is the one I am on and a good one to start out with as well).
Thanks for Aggie12 for the steps mentioned above (with a little extra added from me) from this thread
http://androidforums.com/droid-x-all-things-root/258395-best-backup-use-before-rooting.html
Here is a link that should help you
http://androidforums.com/droid-x-al...ide-root-unroot-backup-rom-sbf-overclock.html
