Root Please Help!!! :(
fuent3zz
alright so this happened to my first phone so i bought a new 1 and again it happened, i rooted my phone and everything was good, i just did a factory reset and im stuck at the clockwork mod recovery and i cant get out of this screen and this is the second phone, and its practically brand new. no matter what i do i cant get out of the clockwork recovery screen any idea what i can do to fix this????
please help i dont really want to spend 100 on a third phone :(
Go back out to the Esteem - All Things Root page and you will see a link name "Lg esteem stuck in clockworkMod recovery mode" and it should help you.
ok so i have the same prob, dumb mistake i know but we all do it now and again, anyways, im stuck in cwm and cant read my ext sd to flash the exit recovery zip. what i want to know is there a way to mount the internal storage while stuck in cwm to add the recovery zip. (my sd card slot is broke as in broke for real, just sos u know.)
when ur in cwm go to install zip from sd then go to downloads it should be in there or go to install from internal
hey all i have got a problem. My phone Lg optimus p970 appears to have trouble with sending texts at times.A red triangle comes up and it says ''message failed' or something like that,well basicly reetting the phone doesnt help and neither does having the app called Handcent or whatever, any help? i cant bare this problem,if you have any tips could you please message me privately as im new here and not sure how to use this ,thanks maya
Happens to me also..but the text does always get send..tested it out with my lady. Was thinking it was a metro issue but not sure.
Welcome to AF:D
The best forum in the world:thumbup:
