Help Please help!!!
I am not sure what is wrong, but it might be as simple as a corrupt SD card, and the phone may be just fine.
When you removed your SD card from the old phone, did you unmount it first for safe removal? If not, it may not be possible to get your music/pics/data back. If that is it, it is possible that your new phone may be fine, but if you're not sure, probably best to have your service provider look at it, and go from there.
The guy at sprint did all the transferring and putting that sd card in my new phone so i’m not sure if he “safely” took it out. I can still play my music just can’t look at my contacts and the camera auto focuses every second on nothing. I plan on taking it in tomorrow and see what they can do
True Dat.... I copied pics, contacts, music to pc then formatted card on phone, then cpoied back to card.
