Hello and welcome Starr777!Hi there my friend a few days ago dropped there phone in water the s3 yes, She can hear but not speak back what part is needed for replacement as all I find is the earpiece flex cable many thanks for any comments in response.
The rice typically works if you pull the phone out of the water immediately, but I wouldn't hold out hope that will fix it -- especially since you've been using it since then. More than likely, the moisture still remaining in the phone has shorted out some circuits.
