Please help
Carlos A
Member
When I got my Galaxy Note 2 in early january the transition animations between apps was like switching cards from bottom to top. However after I updated it to 4.1.2 a day later, the transitios changed into a fade in mode. I prefer the last one, is this permanent or is there anyway to get that transition back.
I have the At&t Note 2.
I'm not sure as I have animations turned off, but you could try looking at the Developer Options in the Settings menu and seeing what options you have there?
Failing that you could try a 3rd party launcher as most of them have different transition options.
