Root Please help
AndroidFantic
Im trying to get back to the Original no root 100% Stock and when i follow the directions and the phone reboots it just goes into a boot loop and never boots up please help me please need my phone and dont want to root
Also i have rooted my phone going on 13 tries now and no success
c:\SDK\tools>adb shell mount -o rw,remount /dev/block/mtdblock3 /system
* daemon not running. starting it now *
* daemon started successfully *
c:\SDK\tools>adb push recovery.img /sdcard
1551 KB/s (3926016 bytes in 2.471s)
c:\SDK\tools>adb push flash_image /systrem/bin
failed to copy 'flash_image' to '/systrem/bin': No such file or directory
c:\SDK\tools>adb push flash_image /system/bin
470 KB/s (9640 bytes in 0.020s)
c:\SDK\tools>adb shell chmod 755 /system/bin/flash_image
c:\SDK\tools>adb shell flash_image recovery /sdcard/recovery.img
mtd: read error at 0x00000000 (Out of memory)
mtd: read error at 0x00020000 (Out of memory)
mtd: read error at 0x00040000 (Out of memory)
mtd: read error at 0x00060000 (Out of memory)
c:\SDK\tools>adb shell reboot recovery
c:\SDK\tools>
It would be helpful for you to be more descriptive about the current state your phone is in. That will give us a starting point.
(1) First, what bootloader is present?
Power off (if possible, or do a battery pull) and remove the SD card.
Turn the phone on by holding down Vol-down and End/Power (red button).
Report back here the first six lines of the display.
eu1
Optionally, if you know how to do it, report the md5sum of the PB00IMG.ZIP file you were using to attempt root with.
Edit: If you have not already done so, download the correct fastboot executable for your computer. (Note that there is nothing else on that page of relevance to you except for the fastboot program - all the other images listed are not for the Eris). While we're at it, what kind of computer are you connecting your phone to: Windows (which version?), Mac OS/X, or Linux?
Nevermind problem has been solved
Solution: loaded the recovery first waited two min. Then booted and turned off and then loaded the hboot.nb0 and waited and then restarted and worked and allowed the update to go through
