please help
vicshalls
I am new to Android and would like to know how to access the ed card to save to it and also get things off of it. Thank you!
plug it into your computer. in the notifications menu at the top bar on your phone slide it down. select the usb connect thing and select mount as disk. then if you have a mac go to finder and you will see NO NAME, click it and thats all your folders on your sd. if on windows go to my computer.
