Root Please need help Cant boot into recovery
adpdopey
Ok so I can not boot into recovery , i hold power button and volume button and when the screen comes up to permantly erase user data & reset settings, i hit power three times but it does not go to cwm, it shows the android and a small box and im guessing it does a factory reset. then it does not boot up, i can get it on and plug it into my computer but nothing else works after setup wizard, is there anything i can do? i have backups on there but can not get through them except through the computer please please help
k go to rom manager and try reflashing clockwork mod recovery
after i do the setup as if it were a new phone the screen is blank except the status bar but when i try to pull it down the screen stays blank, I cant access anything the buttons light up and i feel the vibration when i touch them but nothing comes up
it looks like this
when i do that and turn it back on it loads the lg screen then metropcs and it just stays on metro pcs screen, is there anything i can put on to the sd to fix this? when i explore the sd i see my back ups , thanks for all your help those is so stressful especially when i have a midterm tomorrow
Reflash CWR using the zip file since you cant get into the os to use rom manager. It didnt flash if its going to the android/triangle screen
hey im in hialeah too! I cant get into recovery from reboot, when i press the volume key and power button it and press the power button three times it does a factory reset, then it takes me to the setup wizard and when i finish the setup the screen stays blank like in the picture i posted.
use rom manager and flash clockwork mod recovery then choose ur its under lge esteem tap it then let it progress then after its done reboot to recovery
but how do i get to rom manager , i can not access anything the screen is blank except for the status bar, and when i try to reboot into recovery it does not get to cwm, after i hit power button three times it just resets phone
shit I forgot wat rhodium u on ZVD or b, c
no it only goes to a blank screen with the status bar at the top, when i try to get to recovery and i press the power button three times, it actually resets the phone instead of taking me to recovery . I have it plugged into my computer and i can see the files
i can receive calls and answer them but when i hang up it goes back to the black/blank screen, all i see is the status bar
k try it again but don't hit the power button three times this time its only twice upon gotta hit the power button to reset once then to confirm one more time that's it so give it another try
ok tried it and again it takes me to the setup wizard, i choose the time format language put in my google account and when the setup is done i hit finish and back to a black screen with just the status bar at the top, with 4g battery and time :confused:
can i put something on to the sd thru usb to fix it? could it be i dont have a home launcher? i was using 360 and i only had a backup of the stock home, can i put a home launcher directly to sd?
