I just wanted to know if flashing an sbf (to root milestone) erases all the data and apps. I bought Exzeus, and I do not want to re-buy it after flashing the sbf. Please tell me asap, as I really want root.
All your apps that are downloaded from the market stay in the google cloud. You should not lose any apps by rooting if you have downloaded them from the market. If you have to wipe data, your apps should re-appear once you log back onto your Milestone with your google account.
