Help please... please...please ... halp me!
i am a user of samsung galaxy y s5360. i root my phone from update.zip and then i update the superuser app from android market. then i download fond changer app from android market when i install a fond my phone going to restart and than it steel in boot image and i can't access to my phone .i try to factory reset form system recovery but it said format fail. i am reboot my phone but steel that problem. i buy my phone 3 days ago. i am helpless. what can i do now. please ....please...please.. help me. sorry i am slow in english. i am waiting for help..
If you rooted with update.zip, then you have clockwork mod recovery, correct? The first thing I would do is go into clockwork mod, and go to advanced. Then select wipe dalvik cache. That should fix it. If not, I would find a ROM compatable with your kernel (a stock debloated rom should work, since I doubt you've changed your kernel) and flash that. There are probably a few of them. Just google 'stock deodexed debloated galaxy y rom' and see what comes up. You should find one that can be flashed (installed) through cwm,
I am not sure but I guess CWM was not included in that update.zip
Do you know how to get into recovery on your phone? If so, do that and see if it is cwm or stock. If it's stock, you need to find an odin flashable cwm kernel. and flash it. That will give you clockwork mod. If it's already cwm, just do the wipe I told you about.
Its stock recovery :P.. we have a temporary recovery ported for galaxy Y as of now as it gets overwritten each time..
P.S. I am not OP :)
P.S. I am not OP :)
Sounds like it's a similar set up to our phone. Any time we want to get into CWM, we have to boot to stock recovery, then apply update.zip. But, if this is the case, the op should still be able to get in and do something. This is a simple bootloop . It's not that hard.
agreed, but seems like he fixed it or something.. no reply :/ :P
sir i have no image and how can i flash? plz sir help me
how can i get rom plz sir give me link for download.
how can i get flash.
sir i am in bangladash what rom best for me.
plz plz plz help me!
sir i don't know how to get into recovery on my phone?
what is cwm or stock?
Yuo rooted with update.zip, and you don't know how to get into recovery? How is this possible? I don't know how to get into recovery on a galaxy Y. I suspect its volume up+ home+ power at the same time. If you don't have a copy of cwm, maybe one of the other users here can provide you a link.
you can try these, i copy/pasted it from symbianize but please try it at your own risk
Odin Guide on How to Flash and Install stock ROM Firmware on Samsung Galaxy Y S5360
Quote:
Disclaimer: We shall not be held not responsible if anything happens to your device by following this guide. Proceed at your own risk!
Needed files and tools:
  • Stock ROM - S5360DXKJ3 (S5360DXKJ3.zip) Password: sampro.pl
  • Odin Multi-downloader - http://hotfile.com/dl/142398603/13ab72a/Downloader_v1.84.rar.html
  • PIT file - Tottoro.pit (Only needed for full flashing)
  • Driver - You need to install Kies to get the driver of your phone.
  • USB cable - use the supplied USB cable of your Galaxy Y.
  • PC or laptop - running on Windows or later OS.
  • Your Phone - Samsung Galaxy Y GT-S5360
    Preparation before Flashing
  • Back-up all of your important data stored in the phone like contacts, messages and etc. Flashing will wipe and delete all of it.
  • Ensure that your phone is fully charge or above 50% charge. (If your phone had an auto-shutdown history, and its too old, use a newer or good working battery.
  • Remove the SIM card and the external memory card. (not necessarily but recommended to avoid any certain issues)
  • Hard Reset - We often do hard reset before flashing to clean the memory cache of the phone. Master reset code *2767*3855# .
1. Run the ODIN Downloader on your PC desktop.
2. Load the firmware in the designated button spaces.
Some files came only in a single packed like with tar.md5 file extension., and sometimes a 'SS_DL.dll' file also included on it. Others are confused where to put this file. Well, the S5360DXKK4_S5360LBKK1_S5360DXKK2_HOME.tar.md5 goes on to the PDA button section while the 'DLL' file in not to be used, it only be used on some other issues.
Again the "Repartition" check-box is not to be tick, only the Auto-Reboot and F.Reset Time are checked.
See screenshot:
Setting up the Samsung Galaxy Y into Download Mode and Connecting to PC.
You need to set the device into download mode in order to let Odin recognize it. To set into download mode
Turn OFF the phone, then hold and press the three buttons Volume Down + Home + Power Key simultaneously, you are then opted into download mode screen use the Volume Up button to proceed. If you'll still not get into download mode, remove the battery a couple of seconds then put it back again and then press the download mode button combination again.
Once the phone displays the Android robot and says "Downloading..." Connect the phone to PC with the supplied USB cable. Odin will automatically recognize it if it's properly connected, the ID:COM mapping will highlight to color yellow and says "added" on the log box.
Start Flashing
Hit the "Start" Button when all are set perfectly to begin flashing.
CAUTION: Avoid touching the phone while the flashing already started, any interruption will result into serious issues like soft-brick or hard-brick.
Let the flashing completes, a progress bar displays until the firmware downloading process finishes. It only takes around 3 to 5 minutes, depends of your PC speed.
When a word "PASS" appears, it means that the flashing is successful. The phone will then reboot and after completely rebooted it is now safe to remove it from computer's connection.
check this also http://androidforums.com/behold-2-all-things-root/66867-how-flash-using-odin.html
