Root Please Please Please Please ! hELP MAJOR Problem !
Please Anybody ! Help Me ! Well First Let Me Give You Some Information On How I Think I Bricked My Phone ! Well fIRST I WAS TIRED OF ALL TRHE CRAPPY HOME LAUNCHERS THEY HAVE IN THE ANDROID MARKET , SO I WAS COMPLAINING ABOUT IT TO MY FRIEND GIRL AND SHE TOLD ME THAT SHE HAD GOTTEN RID OF THOSE A LONG TIME AGO SO SHE TOLD ME ABOUT CYANOGEN MOD AND SHE SHOWED ME SHE HAD THE FULL DORID X THEME SHE TOLD TO JUST SEARCH ONLINE FOR THE INSTRUCTIONS AND I DID , SO I FOUND THE INSTRUCTION AND I WAS PRETTY SURE I INSTALLED THEM CORRECTLY THEN BUT THE SAD PART IS I INSTALLED EVERYTHIN BUT CYANOGEN MOD SO THATS WHEN I HAD REMEMBERED THAT I DIDNT INSTALL THEM AND I WANTED TO EXIT CLOCKWORK MOD RECOVERY AND I PRESSED REBOOT SYSTEM NOW AND THAT JUSS TOOK ME RIT E BACK TO CLOCKWORK MOD RECOVERY SO I TRIED TAKIN THE BATTERY OUT AND CUTTING IT ON AGAIN THISS TIME IT JUST STAYED ON THE HUAWEI LOGO SCREEN SO I THOUGHT EVENTUALLY IT WOULD HAVE TO LOAD AND IT WOULD PROBABLY ON IN THE MORNING WELL I WAS WRONG -_______- FML ! SO THEN I TRIED TO CUT IT ON USING FAST BOOT AND THAT TOOK ME TO CLOCKWORKMOD RECOVERY AGAIN SO I COULDNT CUT THE PHONE OFF THEN I TOOK THE BATTERY OUT REMOVED THE SD CARD AND I TRIED TO CUT IT ON AGAIN THEN THIS TIME IT MADE IT TO THE ANDROID SCREEN THEN IT STOPPED CUT OFF CUT BACK ON AND WENT RITE BACK TO CLOCKWORKMOD RECOVERY ! SO IT KEEPS DOING THISS AND I CANT GO TO SLEEP OR ANYTHING SO I JUSS NEED MY PHONE BACK IM REALLY PANICING RITE NOW BECAUSE I DONT KNOW WAT TO DO ILL DELETE EVERYTHING IT DOESNT MATTER JUSS HAAELP ME GET MY PHONE BACK PLEASE BTW I HAVE METROPCS :(:confused:
Use a card reader and plug your sd card into your computer. Download CM6 (or 7, which ever you prefer) and the gapps file, then copy the files to your sd card. Put sd card back into phone.
Boot into ClockWorkMOD and install the CM Mod then the gapps. Restart phone.
oMGE ! IT REALLY WORKED WELL ITS WORKIN BECAUSE I ALREADY HAD CM6 ON MY COMPUTER THANKYOU SOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO M,UCH YOUR AWESOM DUDE @:D
How Do I Install It ? ANYONE CAN ANSWER THIS QUESTION I JUST NEED TO KNOW HOW TO INSTALL IT CORRECTLY . BECAUSE IT SAYS UPDATE FAIL DO I NEED TO TAKE THE BATTERY OUT THEN INSERT THE CARD BECAUSE WHEN I TRY TO ENTER CLOCKWORKMOD IT SAYS UPDATE THEN IT SHOWS AN ERROR SIGN AND IT SAY UPDATE FAILED DO I NEED TO TAKE OUT THE BATTERY ?:confused:
First take off caps lock. Then go to this guide and follow it step by step.
http://androidforums.com/ascend-all-things-root/320265-ultimate-ascend-customization-guide.html
Make sure you are pressing the correct buttons. Volume up, place call, and power.
iM hAVING trouble can Someone take me step by step because its not letting me in stall in saying update error
I'm lost. What have you done? Are you able to get into your phone? Do you have a card reader? Did you wipe your rom and now have no os? Redownload cm6, you may have got a bad download the first time. Put it on the root of your sd card(not in a file just on the card) also put the gapps file there as well. Wipe every thing the guide tells you to and install the rom and gaps.
Does AnyBody have the LINK TO DOWNLOAD CyanogenMod 7 Current Nightly Rom.zip i nEED That Please
The problem is not CM6. Trying to install CM7 is going to result with the same outcome if you are installing the rom wrong. You need to start over from scratch. Also the link is in the guide i linked you to.
Maybe flash to stock and leave it alone until you read over everything...Its all here in the installation guides, flash to stock and go step by step. All the info is here, use it.
It sounds like you don't have CWM installed. Read Tokenpokes guide that was linked above. Re-read the guide. Read the guide again.
Now install CWM as instructed in the guide.
Go to the wiki page for CM6 or CM7 whichever one you are wanting to use and download the files (both the CM zip file and the appropriate gapps zip file).
Install as instructed in the guide.
FOLLOW THE INSTRUCTIONS TO THE LETTER!!!
Good luck.
