Please review my battery performance
Eshyn
I'm trying to figure out if this is normal or not.
I charged from 19% to full 21 hours and 16 minutes ago. The phone sat next to my bed overnight and then I:
Have made/received zero phone calls; no Bluetooth; no Wi-Fi; sent/received about 30 text messages; snapped a few photos; visited one website w/ one or two refreshes and I have one Widget (HTC Clock) running and only have one screen loaded with icons & the Widget -- the rest are blank.
Right now I am at 30% battery level.
As I do feel my battery has improved since I got the phone (last Tuesday) I do feel like I am not using the phone but the battery is draining.
Battery Use is as follows:
Cell standby: 41%
Phone Idle: 37%
Android System: 15%
Display: 4%
Camera: 3%
Thoughts?
Thank you.
Make sure your gps isnt always on...put the power widget works great but that sounds good to me
Are you in a bad service area? Your GPS always on? Live Wallpapers? There's SO much than be running in the background. Do you have 1 or more emails set to constantly refresh and check your inbox?
During the night I was in a fairly bad service area. Now, I am in a good area.
GPS set to 911 only.
No Live anything; no animations.
No haptic feedback or vibrations.
Only 1 email account set up at the moment but am not sure how often it is checking for new messages. How do I check this exactly?
Thanks.
Thanks.
depends on what the app is. It's either in settings> Accounts and Sync.....or in the app's settings itself if you use some funky 3rd party thing
