Root pleaz help for russian
Status
Not open for further replies.
ruslan83
Hello! Sorry for my english, I'm from Russia. Need your help. Could you throw me two files from your firmware "modemst1, modemst2."I want to unlock your phone, it is locked by our operator. Thanks in advance for your help.
i dont know if thats gonna help you. its a cdma phone, no sim card or anything so technically it cant be "unlocked"
no, they cant be. this phone has cdma, which cant be unlocked... and lte which does use a uic card, similar to a sim, but the problem is its embedded, so even if you could unlock the device to be able to switch the card out, i hope you got some really good soldering skills, and it would only ever get lte no phone service
plus, thats not firmware... thats your actual modem partitions. which would have a persons serial numbers and everything if im not mistaken
not sure what the last part was, but chipset dont mean anything i asked what kind of phone it was. model name
basically, im gonna break it down like this. if you could unlock the firmware for this phone, you could unlock your own firmware... but either way it couldnt work because cdma is a completely different type of connection, its like trying to hack bluetooth with wifi firmware, two completely different types of signals. so either you have no idea what youre talking about, or youre trying to steal someones account info, either way its not gonna happen
sprint/boost/virgin use cdma, so that v9800 can NOT work on boost mobile, it is a gsm phone, it uses imei and a sim card, boost phones use cdma which is a meid and in the case of lte it has a sim but this particular phone has it embedded so it can never be changed out, and even if it could its not a gsm sim its an lte uim, there is a difference
so whatever youre trying to do, its not gonna work, youre gonna have to get over it
Okay, no help from you. Your accounts I do not need. I'm just trying to unlock your phone. I have a notion of what I do, are not you clever Here, there is one. So if you have nothing else to say, retire. Good luck to you!
all im saying is for nobody to give you that info... because theres no way you can unlock our phones, and even if you could we cant swap sim cards, so it wouldnt help anyone. if you can unlock you can unlock your own
im sorry dude, but there is sensitive info in there, serial numbers, usernames and passwords, and i know more about cdma than you would ever believe, there is no way to unlock it, that is not how it works
The question has been answered. The files requested contain personal account information and should NEVER be shared. The technologies are not compatible, so a firmware hack won't make it work. CDMA phones are not locked on the device, they are permitted on the network by the carrier.
There's really nothing left to discuss, so I'm locking the thread. If you think there is any need to re-open it, send me a PM. :)
Status
