pls help me
marize
hi :) i just need an explanation bout my phone... i just reset it and now i can't access my gmail ... here's the pop up message:
"can't establish a reliable data connection to the server. this could be temporary problem or phone may not be provisioned fo data services"
what should i do?
Welcome to the forum. :wavey:
Which phone do you have? You can probably get better help by going to your phone's specific forum.
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
