Help PLS HELP ME
I rooted my phone and worked for like 7 days then suddenly when i tried to go google play or youtube it says that check internet connection and try again. How i can fix this?
My phone:
Samsung galaxy trend 2
What app i used to root?
Kingroot
When i rooted mysamsung galaxy trend plus like 5 days it worked. I had font installer and i downloaded font and i had to reboot my phone that the font will come but when i open my phone theres is only Samsung picture like when you press button long time so its open. Can i still save my phone or wil it be brick all time or something
My phone:
Kingroot
I guess you should verify your internet connection and/or your status...
Otherwise maybe your root application was fake
Did you take a nandroid backup before doing this (i.e. a backup made using a custom recovery)? If you did this is trivial: go into recovery and restore the backup.
If not, next time please do so before messing with the system (and even fonts are modifying the system).
This is fixable, but I'm not a Samsung expert, so can't tell you e.g. how to flash the phone back to stock. Can you tell us whether you have a custom recovery or not, as that will tell us what options we have?
If it worked for a week then rooting isn't the problem. So what did you change or install before it started? Is it all apps, or just these Google apps, that have problems? Just mobile data or WiFi too? Knowing these things will help identify the cause, and hence the solution.
