Help [pls help] rooted desire cm7 bootloop after flashing zip!! Bricked??
vishnuu09
HEY UM I REALLY NEED HELP FAST!!!
YESTERDAY I DOWNLOADED A ZIP FILE (THEME) FOR CM7.0.3 .. AND IM USING AMONRA 2.0 .. I FORGET I WAS USING AMONRA AND INSTALLED THE ZIP WITH ROM MANAGER... AFTER INSTALLING MY PHONE JUST WENT INTO ENDLESS BOOTLOOP AT CM LOGO... NOW I CANT DO ANTHING EXCEPT GO INTO RECOVERY.. BUT RECOVERY DOESNT WORK BECUZ IM GETTING A MOUNT ERROR I CANT WIPE / INSTALL / RESTORE OR USB - MS! I TRIED WITH DIFFERENT SD CARD AND SAME.. WHAT DO I DO?? AND I DONT HAVE A MEMORY CARD READER SO I CANT ACCESS SD FROM PC. ONLY THRU THE PHONE , WHICH ISNT WORKING:mad::mad::mad::mad::mad::mad::mad::mad::mad::(:(:(:eek::eek::eek:
First, do not post in bold letters! It is considered shouting and I can hardly read it.
Second, why did you have to use that crappy ROM Manager? We have warned about that so many times here...
Can you flash the Recovery again (AmonRa or CWM)?
thanks for ur help... how do i reflash AmonRA?.. (im nt using CWM becuz it has issue with PVT4) ... and i just sent it back to HTC.. thought no one would help..
The process is described in the rooting guide in this section: run UnrEVOked and pick up the Amon-Ra file.
Usta replied 6.5 hours after your post, which was sent in the middle of the night for many of this forum's members. You should perhaps have given us a little longer.
I hope HTC don't give you trouble about sending back a phone whose software has been modified.
In future my advice is to delete ROM Manager. If it comes as part of a ROM and you are not S-Off then use Titanium to freeze it. You don't want it on your phone.
I know it's a little late for this advice, but for problems like this the "all things root" forum may be a better place to post - that's where the people with experience of this type of problem are most likely to be found.
Anyway, good luck.
