brainfogbetty
I rooted an SD card with Cyanogen Mod7 Gingerbread. The Sd card is 16G. Everything works just fine with a few exceptions.
1. My SD card shows FULL which it's no where near full. How can I get to the PDF files I have on my SD card while running Gingerbread? They are not showing up.
2. When I have the SD card in and boot up with Gingerbread, I can't get to any pdf's ( or any files) I have loaded onto the Nook. I'd like to use the 8g storage on the Nook if I can.
3. When I try to read a pdf while running Gingerbread, it says I need a program ( EZPFD reader) which I have but can't access it because it doesn't show up on my SD card and I'm not going to buy it again unless I absolutely have to.
It's a miracle in itself that I was able to root the SD card by myself with no problems. When I look back at the instructions, it all looks Greek to me now..
Can someone help and explain in a 3rd grade level so that I can understand? Please, please.
