.pls player
You're best option is to take that .pls file you have, open it with a text editor, take the urls that are in there, and put them in Browser. You can also try out nswPlayer from the Market also. Hope this helps!
I love Dubstep FM, Gremlin Radio and a few others. I'm looking for a solution for this as well and will post one when I find a good one.
OK, I installed a ton of apps, found DoubleTwist to be the best and cleanest interface. I didn't see Dubstep.FM listed, but I'm sure it is there somewhere. Try it, I'm sure you will be happy with it. I am.
