Root Plus' to Rooting
pEktaS
Member
I did a search for posts on this but couldn't find anything, but my question is what are the perks to rooting? I know there are more apps but what sort of apps/what sort of stuff does it allow me to do. I want to make sure its worth the risk that comes along with it for me to do it, i don't wanna risk my phone if its nothing i will ever use.
they have a 1 click root out right now so its pretty easy to do and as for the perks you can use your phone as a wireless router and use other 'root' only apps
thats what im asking, what kind of apps are there. I read the favorite root apps post and nothing blew me away most seemed to deal with protecting your stuff like the titanium backup i want to know if there are things that let us make the phone os look cooler or something or just anything other than just being able to take screen shots of my phone cause that isnt worth the risk to me i dont think
Well if you're looking for better battery life, setting up SetCPU properly will give you quite a few more hours. It nearly doubled mine. There is also practically no risk rooting the phone itself, its what you do with root that can potentially screw it up.
With my Droid 1 the biggest plus for me was theming and source based ROMs...but right now custom ROMs aren't possible and theming is just too risky IMO because there's no nandroid backup. You piss off that bootloader and you're done.
Once I get my DX, I'll probably root it just to get rid of the bloat ... but I'm really going to miss the themes.
check out the favorite root apps thread here: http://androidforums.com/all-things-root-droid-x/131944-favorite-root-applications.html
after rooting my DX, i noticed it being snappier and more responsive. this, and wi-fi tethering, has made rooting worth it for me.
