Root plz help :/
xdroiduserx
ok so i normally use astro to clear my twitter widget cache as soon as i go in i go into the android folder of the internal sd card & wipe the twitter cache but i started deleting other things i wasn't sure of what they were atm to free up some more space & accidentally ended up messing something up. now when i go to my gallery only about 3 or 4 pics will show up, they are all there n i can see them when i click on thumbnail but mostly all thumbnails look like this .. http://i46.tinypic.com/nqea37.jpg with the exception of like 4-5 . what can i do to fix this ? is there a way??:confused:
Try going into settings>applications>mange apps and at the top hit all apps and find the gallery and delete the data and then try to open it again
connect your phone to your computer then try to locate the images and see if they are still there and if so back up everything and do a factory reset.
