droidobsessed
I would like to root but I want to be able to get the ota's. Advice?
As far as I know. rooting doesn't have any effect on getting the OTA updates. It's when you root and install a custom rom that effects OTA updates.I would like to root but I want to be able to get the ota's. Advice?
Should be fine. I'm on my 4th android device, I've rooted every one of them, and still got OTA updates up until the time I installed a custom rom. Bloatware removal was the main reason I rooted and it didn't affect OTA updates.Ok. So if I root and uninstall bloatware I am still good? Thank you.
In my experience, on 4 different android devices over the years, this wasn't the case. Removing bloatware had nothing to do with whether or not an OTA updated succeeded. Rooting does nothing to change the OTA updates capacity of the phone. Installing a custom ROM, on the other hand, is what will keep the user from getting OTA updates.If you root and uninstall bloatware, you are modifying the system files so the OTA update will fail.
Wowsers, I guess I've been lucky on these 4 devices over the years.
That's a very good point.. and I'd have to agree with you.It's just a choice by the manufacturer. Just depends on how extensive the sanity check is by the updater. Virtually all updaters check for their dependencies before modifying the system, the Blur updater just checks for a fully intact /system/ partition or whatever before it rolls out the changes.
It's actually not a terrible idea because you really don't want to push updates of any kind to a device with unknown modifications. For all that we love to point at Moto and cry foul for their many poor choices, I would probably design my software updates to do the same thing. I wouldn't want my software updates touching a device that had its system modified.
