Trying the Samsung S for the past 3 days - coming from N1.
So far I am pleased - elegant design, lighter, slick Black look, fits in N1 pouch, beautiful screen.
However, with moderate use the battery lasts 12 - 13 hours maximum.
At 8-9 PM the phone is dead.
Everyone is saying that the battery is actually better than most Android phones - so is it my phone? Am I the only one with battery problems?
Any suggestions?
When I check the battery usage I see about 40% of it went to SCREEN - although I set it up to minimum brightness.
I am using NOLED - does that use a lot of juice?
Also - if you could suggest a good battery saver program THAT WORKS it would be great.
I am getting a bit worried - wouldn't want to give this phone back but battery is an important issue.
Thanks guys.
Any suggestions?
Thanks guys.
