jreink01
Android Expert
I have a triumph that is rooted and flashed with CM7. It seems like Im having problems with my signal. I am usually getting 1 bar at home, 2 if Im lucky. I downloaded the app OpenSignal and the last couple of days, it has connected to at least 3 towers within a mile of where Im at (according to this app), and still, I have not gotten more than two bars on my signal. My speeds according to this app are around 50mb. Am I suppose to be getting a stronger signal and faster downloads with these towers being close? In the OpenSignal app, it shows being connected to one of these towers but Ive noticed at times it will just change to a different tower. Is this normal??
Also, Ive noticed, When I make a phone call, it takes several minutes for the 3G to come back on (signal turns green), is it always suppose to do this??
Also, I inserted the build prop file (ro.product.rat=EvDo only) just above the the wifi file with ES Explorer. From what I gathered, this is supposed to keep me on 3G but it still goes to 1x quite often. Is there anything I can do, or am I doing something wrong? Thanks for the feedback..
