Help Possessed Desire Z While Charging.
jd32
Does anybody else have a similar problem.
My Desire Z seems to have a mind of its own, with phantom scrolling and key presses occasionally, but most of the time it seems to put shortcuts on my homescreen by itself, and tries to remove them.
When you press on an icon and hold it down, you get that menu that allows you to remove the icon or edit it's properties, well this seems to happen quite often even though I know I didn't press anything.
I know there have been previous posts elsewhere about this, and usually cleaning the screen or trackball seems to work, but it doesn't seem to be the same problem.
I have noticed that this usually only happens when the phone is charging, but unfortunately with the Desire Z this is quite often..
It's not a major problem, more annoying than anything...
Thanks ...John...
