Nothing seems to work for me, outside of using it for awhile throughout the day. Then it seems to magically work again.
on my 3rd still no issueClearing the data has never worked for me.
Same, it seems to be completely random for me. It works fine 90% of the time, but when it starts FCing, nothing seems to fix it but time.
I did another factory reset Friday night. Its still happening, but it does seem hit and miss as to when it works.
Did you do the clean reset?
In Clockwork recovery I went to advanced then reset battery stats.
Okay, I'm seeing the fc issue for the first time, and want to try this fix but don't see the option to clear the data under running services. Is it specific to the battery manager? Because I don't have that as a running service either.the ongoing issue with battery manager force closing
my fix is that i go into application/running services/ clear data
and problem is corrected havent had an issue in 2 days
hopes this helps you guys
I think I may have found something. Since I upgraded to Froyo with the leaks and now to OTA I have never got the battery manager to work. 100% failure. I tried something that fixed it for me. In Clockwork recovery I went to advanced then reset battery stats. Then I cleared cache partition. For the clear cache I don't think this matters but who knows. I restarted my phone and dam, it works now. I did cold restarts to the phone and so far no force close.
Hope it helps.
Under running services go to battery manager then go to clear data
Hope it helps.
Hope it helps.
