Root Possible brick?
UnLucky
Member
Running Liberty 2.0, having a ton of problems with it, I backed up, installed and ran the GB apk to root it, wiped, booted into recovery and tried to install ZombieStomped and it got stuck at a Liberty boot screen. Apparently this isn't the correct route to GB? I can't get into clockwork either.. HELP.
Hold Menu and Power button to goto Clockwork recovery. If you are unable to load a backup from there, then you need to look into doing a SBF recovery
menu + pwr? Never heard of that c-c-combo. And to the OP. If you're stuck on the liberty logo and can't get to CWM then you will ultimately need to SBF because system files have been corrupted.
^^^^^^What he said. Unfortunately there is no short cut to Gingerbread until OTA. You MUST SBF to a clean 2.3.340 and then flash to a GB ROM. Unicoder, Power + Home (thanks aggie) will get you into the stock recovery mode. Not CWM. If you are on GB and you get bootloops, it is correct to go into stock recovery and wipe data and cache.
U D G this site has all the information and files you will need.
It's pretty pro. Check it out and come back with any clarification you need.
