Root Possible ROOT found! Not Kidding!
It isn't working for me for some reason. Neither option.
Check that:
1) You have USB debugging enabled.
2) You have the USB set to "charge only"
3) When you plug it in as charge only drivers install successfully
4) You are plugging directly into the usb on the motherboard (back of the computer). Sometimes front USB ports and usb hubs can make these kind of things not work.
Hope that helps,
