I have no idea if this was just a fluke or a real fix, but I have been dealing with my phone shutting off randomly for months. It's just something I accepted and make a point of checking it often to make sure it's on. Especially when expecting a call.
Finally two days ago, I had to reset to factory settings because of that stupid problem with the text numbers (you know, where by accident you forget to put the number with area code and that's it, the phone NEVER adds the area no matter what you do??) but this time, I didn't install a single app. Not one!! Just left it like the factory gave it to me and only added my contacts. (making sure to add that one that I screwed up with the area code this time) and.. I have not had a SINGLE shut off in two days!!
It used to be like sometimes several shut offs in an hour.. then it would go okay for a few hours, but never more than 5-6 hours without a shut off.. never!
Until two days ago.. two days gone and still running strong without a single shut off and I have changed the battery twice in that time. (I do that thing where I have one charging in the charger while using one) Still, everything is running smoothly.
I have no idea if it's just a fluke or not or if the shut offs will happen again, but going two days without a single shut off is a damn miracle since I've had this phone.. made me feel it might be worth sharing.
