andoc2012
Hi there, would be very happy with some help on this one!
I have the S2 and like to stream online radio often. I've found recently that with WIFI on at home, I can power down the phone whilst streaming, the radio momentarily switches off, and then when I power on the phone, the "keypad login screen" recommences playing the radio again. In this login screen, the display stays on keeping the radio playing, but eventually the screen lights dim conserving battery power.
When I try this with WIFI off just using the network data, and repeat the same process, it won't stay fixed on the keypad login screen. It powers off automatically after the allocated power-down time causing the radio to switch off.
I've tried changing the settings to leave the display on for 30 minutes, but obviously that drains the battery FAST!
Is it possible to stream radio out of WIFI range ... preferably with the display completely off?
Any ideas?
Cheers
Any ideas?
Cheers
